lavron
I have been scouring the forum looking for how folks have been dealing with 250 deck height issues and have a few questions.
First I want to reiterate what my end goal is and the means that I am attempting to get there - I want a dependable build that utilizes fairly commonly available parts, this would be, initially, the parts that are most prone to failure (starters, ignition, pumps, etc.) followed by major components that may need replaced in the future (brakes, clutch, etc) I am looking for a road car the can fairly dependably make a 1,500 mile trip with out too much concern, I would like a well performing car but not high performance (it will never see a drag strip or most likely any form of performance competition). I am attempting to get there on a low budget, mostly as a proof in concept that it can be done.
With that said I understand there are certain things that cause the budget to be higher like using the 250 when a SBF would have been way cheaper and easier, but these are personal preferences because they are what I want
With these things in mind I am currently looking at deck height issues, while I know I could leave well enough alone and go all stock Ford 250 rebuild parts, but I would like to make it a bit better in the performance arena if I can without causing much issue.
First off, I need to bore and deck the block anyway (engine has neither been bored or decked in the past) so I will be replacing pistons, I think a .020 overbore will work but may be a .030 - I have been looking at the Oz 250 pistons 3328H, Summit lists them for $150 a set (not sure this is the cheapest place) and RockAuto list stock 30 over pistons for $130 a set, this is pretty much a wash in price. So basically I could get the piston .030 higher up in the bore. I know about the 255-V8 pistons but they are over $200 a set and I can't find rings for them hardly (unless they use 200-250 rings?)
What is a safe number to deck the 250 Block, it seems .030 - .040 is fairly common?
I know I won't achieve the desired zero deck height but I can bring it down some, it this a help or just as well leaving it stock?
I also have the forged stocks rods for what it is worth :roll:
I know you guys have been on me to CC my head chambers and I will eventually get the stuff together and get it done, I just haven't had a chance yet.
Anyway I will start there on just those 2 things
See Ya,
Mike
See Ya,
Mike
