falcon_master
Hi everyone. I made another video with the engine running now. I fixed the Gen light but I have to polarize it every time I start it otherwise the light goes back on. For the ign setup I have a wire coming from the positive side of the solenoid to a ballast resistor then through the hole in the firewall where the choke cable runs through to a 20 amp toggle switch then from the switch to the coil. The system works great. I took a "test light" (a small replacement dash bulb) and found what works had voltage and when. I found that my ign wire does fact get voltage to the coil the headlights, dash lights, and horn all get voltage.whre it gets interesting is that even when I'm holding the key on start the words to the solenoid where start is marked is getting so little voltage the light barley goes on o couldn't tell at first. So some work I still needed lol but the solenoid is ok at least.
Here is the video
https://youtu.be/hpph8tZvjZw
Here is the video
