Degreeing the Cam
StarDiero75
Degreeing the Cam
Post #1 by StarDiero75 » Mon Mar 16, 2020 11:23 pm
Howdy guys,
So with my cam I just finished degreeing it. My cam card says, 112 lobe sep and degree intake lobe to 110. After doing the .050" before and after, i got 107 degrees on the intake. Does that mean I'm 3 degrees advanced or 5 degrees?
Thanks,
Ryan
Econoline
Re: Degreeing the Cam
Post #2 by Econoline » Mon Mar 16, 2020 11:44 pm
5
It ain't gonna fix itself
StarDiero75
Post #3 by StarDiero75 » Tue Mar 17, 2020 4:15 pm
I double checked it, i was alightly off. It is at 109.5, so only 2.5 degrees advanced, thats where its staying
wsa111
FSP Moderator
Post #4 by wsa111 » Tue Mar 17, 2020 4:56 pm
That's perfect, the timing chain will stretch will bring you back to the 2 degree advance setting.
CNC-Dude
Post #5 by CNC-Dude » Tue Mar 24, 2020 4:41 pm
Its actually not 5° as mentioned above, your reading on the intake centerline of 107° is 3°advanced. The separation angle of 112°is fixed and cannot be changed without having the camshaft reground, and is not affected by advancing or retarding the camshaft.
CNC-Dude
Post #6 by CNC-Dude » Tue Mar 24, 2020 4:43 pm
StarDiero75 wrote:I double checked it, i was alightly off. It is at 109.5, so only 2.5 degrees advanced, thats where its staying
It's only .5°advanced, or close enough to call it on the money based on the cam cards recommended 110° on the intake!
Econoline
Post #7 by Econoline » Wed Mar 25, 2020 12:37 am
The concept of "ground in" advance is only relevant if the cam is indexed properly by the grinder. i.e. when installed on the dot's it's got, in this case, 2 deg advance. 107 c/l would still be 5 deg advanced. Sounds like they got it right. 2.5 is good.
drag-200stang
Post #8 by drag-200stang » Wed Mar 25, 2020 8:42 am
I like to check my work on the the center line method, by also checking that the valve events match the cam card , while only turning the crank clockwise.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
Users browsing this forum: No registered users and 20 guests
