200 Deck Clearance
sarnett346
200 Deck Clearance
Post #1 by sarnett346 » Mon Mar 30, 2020 12:42 am
Hello all,
I’m tearing down my inline 200 and I’ve come across something a bit interesting... I measured the deck clearance and came up with .040
As far as I know, stock should be .019, I’m stumped. Pistons are NP275.
Can anyone explain how this may be?
Thanks,
Sean
chad
measuring the i6 Deck accuratly
Post #2 by chad » Mon Mar 30, 2020 12:50 am
"...explain how this may be? ..."
incorrect method of determining? IDK...
Econoline
Re: 200 Deck Clearance
Post #3 by Econoline » Mon Mar 30, 2020 12:54 am
Aftermarket pistons have lower pin height than stock. They do that to compensate for decking i suppose.
It ain't gonna fix itself
sarnett346
Post #4 by sarnett346 » Mon Mar 30, 2020 9:43 am
Econoline,
I figured that’s what it was, just couldn’t find any measurements online to back it up.
pmuller9
Post #5 by pmuller9 » Mon Mar 30, 2020 10:47 am
The replacement pistons usually have a CD of 1.500" and the stock block if it hasn't been decked can be a few thousands higher than spec.
CZLN6
Post #6 by CZLN6 » Mon Mar 30, 2020 1:09 pm
Howdy Sean:
Did you measure the deck height on this engine before you tore down? Always a good Idea. Stock 200 blocks deck height typically measure around .025". Replacement pistons are down .005" to compensate for machining to true the block.
Users browsing this forum: No registered users and 16 guests
