Coil Resistor
DaGr8Tim
Coil Resistor
Post #1 by DaGr8Tim » Sun Jul 07, 2013 2:44 pm
By the looks of the 77 232 in my CJ, it has a resistor before the coil. I get 12.8 volts into it and 12 volts out of the resistor. I'm not getting any spark and I suspect it's a bad coil.
A friend gave me an Accel 140001 (http://accel-ignition.com/original-supe ... oints.html) coil that he had kicking around from a waggy project he sold. I'm wondering if I need to run the resistor with this accel coil, or if I can run it straight off the ignition wire. The instructions (http://accel-ignition.com/media/instruc ... 140001.pdf) say to run an Accel resistor (http://accel-ignition.com/ballast-resistor.html) with your original resistor. But then again, I think that is assuming you are running a points distributor. I wouldn't think my 75 with a 77 motor would be running points.
Also, I got the coil used with no adapter on top. How can I rig it up to fit the fitting on the wire from the distributor to the coil?
Hopefully this solves my no spark issue and and I can move on to the carb.
Read more: http://www.jeep-cj.com/forums/f7/coil-r ... z2YO1dL3eq
A)bort, R)etry, I)nfluence with large hammer
1997 Jeep Cherokee
1975 Jeep CJ5 with a hacked CJ7 tub
300 6 JEEP
Re: Coil Resistor
Post #2 by 300 6 JEEP » Thu Jul 11, 2013 7:33 am
I never had any luck with the Accel super coils burnt three of them up over 1 year and gave up... I ran them with the resistor and without and the same. does your jeep have the ford style Ignition box? I can't remember how far they went back I know 1979 they had them.
"CLANK" It is alright she WILL hold together!
300 with some goodies:) Soon to be FI
NP435 with Granny low
Dana 300 T-case
Dana 44's Front and Rear Locked
and loves to beat up V8's
DaGr8Tim
Re: Coil Resistor
Post #3 by DaGr8Tim » Thu Jul 11, 2013 9:15 am
300 6 JEEP wrote:I never had any luck with the Accel super coils burnt three of them up over 1 year and gave up... I ran them with the resistor and without and the same. does your jeep have the ford style Ignition box? I can't remember how far they went back I know 1979 they had them.
I'm not sure. There doesn't seem to be an ignition box anywhere. One suggestion I got was to get a 79 distrubitor and do the team Rousch mos to it, which I believe uses some parts from an early 80's 300.
1997 Jeep Cherokee
300 6 JEEP
Re: Coil Resistor
Post #4 by 300 6 JEEP » Fri Jul 12, 2013 7:45 am
Mine was located down on the inside drivers side fender. from what I have found on the net they use the ford style module from 75 and up.
Dana 300 T-case
DaGr8Tim
Re: Coil Resistor
Post #5 by DaGr8Tim » Fri Jul 12, 2013 7:48 am
300 6 JEEP wrote:Mine was located down on the inside drivers side fender. from what I have found on the net they use the ford style module from 75 and up.
I'll have to take another look. This thing is cobbled and that could be the reason I'm not getting spark.
1997 Jeep Cherokee
80broncoman
Re: Coil Resistor
Post #6 by 80broncoman » Fri Jul 12, 2013 1:57 pm
A 79 dizzy for a Jeep 6 is a duraspark I unit. both the Jeep with 6s and V8s had it. you would still need the resister with it.
No matter what I can't see you needing 2 resisters.
OAPSE Union Member
Real men don't wear Bowties
