Daves55Courier
I installed a Holley model 12-804 fuel pressure regulator in Mar 2006 and it failed in July 2009, then I replaced it with a simpler type regulator mfr by Mr Gasket, model 9710 and it has failed. So that second regulator only lasted 13 months. Hmmmm. Both failures occurred during the heat of summer. I had a habit of installing the regulators close to the carb, and in doing so, they were exposed to maximum heat since that is a few inches above the manifold.
If I move the regulator close to the fuel pump, it may be cooler since that is down low and on the opposite side of the engine as the exh manif.
When both failures occurred, it was very hot, the Holley 1904 glass bowl carb flooded and died as if the regulator didnt exist. The expensive Holley regulator did not respond to adjustment on the spot and allowed full force gas to inundate the float chamber. The cheap Mr. Gasket regulator did allow me to resume my trip after I dialed it down to 1.5 # pressure and left the hood open for heat to escape for about 7 minutes. I originally had it set to 2 # and never had a problem with it till now.
Anybody else have this problem ? Is heat detrimental to proper operation or are the regulators just faulty ?
Is my regulator ruined, or will it operate correctly if I move it away from the heat ?
