223 performance build...questions!
GalaxieInline
Active member
Just signed up for the forum to ask some build questions!!
I'm from Indiana, I have an uncommon 1963 ford 300 (below the base galaxie) with a 223 i6. I have built v8's and love classic engines...I've always wanted to build a six though!!
Here's what we got so far:
stock 223 with clifford 6=8 2x2 intake
-2 weber 38/38 dgas synchronous carbs
-clifford split header dumping into 2.25" dual exhaust w/magnaflows, h pipe, and hidden turndowns behind the rear bumper.
- pertronix ignitor ii with flamethrower 40kv coil and autolite plugs gapped to .045
-ford 300 distributor conversion (223 12t timing gear bored out to fit 300 shaft, 5/16" to 1/4" oil drive adaptor fabbed) ditched the terrible load-o-matic dizzy.
She runs STRONG now, motor was pulled last week and is at a local top-nitro engine builders shop and we plan to do the following:
-clean, flux, check head and block
-turn crank/rods
-shot peen rods, arp bolts
- 60-80 over with aluminum hyperutectuc pistons (engine guy says she can take 80 easy as the walls are thick enough to go 125 over!)
- mild port head, blend ports, deck to raise compression to 9.5:1 if possible, 3 angle valve job, hardened seats and overcut for larger SBC +.100 swirltip valves and heavier SBC springs
-chamfer all oil passages and a new 5/16" melling oil pump
- 265° Clay Smith bumper /higher lift and duration, designed for torque applications.
- fully balance and relieve the motor for smooth revving and ability to stay together up high on a 4 main.
Currently the motor has been pulled and is being torn down and hot tanked and fluxed.
I'm looking for any advice as we plan this awesome project! Shes sure to surprise a few v8's even in the big 'ol galaxie and sure to turn heads at shows!
-Anyone have any tips and tricks that work well for these motors? I've read that they have the same offset combustion chamber that the Y blocks have....and similar valve shrouding issues. Should I be at all concerned with relieving the block/head to try to get the intake velocity up with the bigger valves?
- I can find Keith Black Silv-O-lite's for her, but nothing else affordable...any other common off the shelf Sbf or Sbc pistons work in this motor?
- any affordable H beam lighter rods that will fit this motor?
- what's the best way to about porting the head and getting flow up while retaining velocity needed to make low end torque?
I've done my homework to the best of my abilities...not a TON of info on the 223 at all...shes being rebuilt the up coming 2-3 weeks so any info I can pass along to my engine guy would be awesome!!
I used to race the 223's back in the mid to late 1960's! I did a very detailed post awhile back going over some of the things I learned on these 215, 223, 262's Ford six engines (see the below link). Take a look at it and see if there is anything that can help you. Yes you are correct that the head to block on these 223 are like the Y Blocks and they also share a few engine parts the heads also respond to the same porting technic's used on the Y Block heads. There are some other members that made posts on these engines and head flow too, so try using the sites search feature for those. You have a good plan and some really decent parts already. There where also some Hi Ratio rocker arms that were made back in the 1960's by Baker every so offen some will come up for sale. The stock cams can also be reground by some of the Cam Companies Scheider is a very good one. Another great upgrade is a T5 trans swap unless you already happen to have a 3 speed with the bullet proof overdrive (R11) which will let you split the gears (giving you 6 speeds with a simple mod) it will also allow you to use lower gears for a good hole shot while still retaining decent fuel economy. Jack Clifford did a lot to improve these Ford six'es if you can find some of his old tech manuals from back in the 1960's and 70's there is some very good info, but sadly with his passing much of his great info has also been lost and is almost unavailable except from a few old timers that were around back then. There is nothing l liked better than beating those V8's by leaving on them out of the hole, yet the overdrive gear gives you back back some economy and good freeway cruseing speed, truely the best of both worlds. Good luck in your 223 build up. :nod: Edited
Info on Ford's First Overhead Valve Sixes The 215, 223, and 262 Used From 1952 to 1965
Cam Regrind Service
Autotec / Ractec Forged Pistons has about the best price on making a set of Custom Forged Pistons
Post on 223 Head Flow numbers
Bubba22349, thanks! I've poured over any and all 223 threads I could find on this forum and your information proved to be some of the most valuable! My motor is apart and my engine guy has told me the following:
The bad:
-Rod bearings down to the copper (ouch)
-pistons worn out
-TONs of sludge...well it's a 223 so nothing new there..
-valves were mostly stuck open, seals were halfway up the stems...
-timing chain shot...1" of slop!! God no wonder I could never get her timed right!
The good:
-block is good
-crank only needs .010 to turn it
-rods look fine, will be relieved, shot peened and lightened
-cam looks like an accepably grindable core
-head is straight and buildable and has was fluxed and checked no cracks etc
So basically the bones are good, no bad scoring on the bearing surfaces etc. Water passages look nice and clean too. He's tanking the block for me today.
I spoke with Clay Smith today and they recommended Sealed Power 1011P pistons over the Keith Black ones...can't seem to find anything other than cast For this motor. Unless there's an off the shelf forged that you know of? I called Egge, they didn't have any pistons available for the 223...the guy did say that 254 Y block are close/same.
I'm finding conflicting reports on what the stock rocker ratio is on this motor, is it 1.45? I can't find ANY of those baker high lifts.
Bubba, since you used to race these...would you mind talking on the phone about some of your experiences? You can PM me if so, but if not I understand :)
I also just dropped the valve cover, side plate, timing cover, and oil pan off today to get them chrome powder coated...way cheaper than real chrome and will look pretty good when done.
I had a set of forged pistons made for my 254 cu in flathead six at Ross Pistons in California. I sent them an old piston and required bore and they went from there. They even provided rings. A little pricey but worth it. Check out their website.
The bad:
-pistons worn out
The good:
-block is good
Glad to hear that all the main 223 hard parts are still in such good condition having a crank that will clean up .010 on a 223 now days is rare. The pistions should be easy to get depending on your budget as the pervious poster stated there are Compaines that can make custom Forged ones like Ross, AutoTec, Venolia, etc. with most you will be able to pick your compression height so you can get to a Zero deck height, plus go with the better more moderen Ring Packs that will give you less friction and longer engine life, things that weren't available back when I was racing them. On rocker Arms you can contact Rocker Arms Unlimted
http://www.rockerarms.com/pages/ford.html
They do offer rebuild services for the 215, 223, 262 rockers and can also convert some rocker arms to a Higher Ratio so you might give them a call to see if they can work with you. The 292 and 312 Y Block V8's of certain years (performance versions Like the T Bird engines) also had high ratio rockers arms but sadly they are a good 1/2 inch shorter and can't be used on the 215, 223, the 262 Sixes. Maybe I can talk to you on the phone though I really don't have much free time since I started working full time again. So I probably can answer your questions faster here on the site. Good luck on your 223 engine and let us know how your doing on it as you can. (y) :nod:
progress:
-crank turned .010
-rods lightened, relieved (ground casting ribs smooth), new clevite bearings/wrist pins.
-found ARP rod bolts and main studs
- rocker assembly was trashed, found a NOS TRW rocker assembly on ebay for $185 delivered. Not bad considering new rockers alone are $240. Unfortunately, Y block rockers are too short to work on the 223 by about 1/2"!
-head is being worked, engine guy found a way to make a 2.00" SBC stainless undercut swirl valve to work on the intake, he is going to be turning them down and working the bowls, then doing hardened seats and an angle job.
-I found a cloyes heavy duty timing chain/gearset, was going to go with a rollmaster but I dont think ill have any issues with the cloyes HD...should be better than stock.
-new comp cams lifters
-just won a 292 Y Block flywheel (direct bolt on) on eBay for about $45 shipped, going to run this to have access to 11" clutches and pressure plates. Very limited selection in 9.5."
- I looked into having a custom set of pistons made, but it was going to break the budget. I'm not going to be hammering it all of the time so I think the cast will be alright. I found a local place that actually had Sealed Power 1011p80's in stock (.080 oversize.)
Last thing I need to find is chrome rings for 80 oversize...seems a bit difficult to locate...would one of the formentioned companies you sugguested carry some?
lastly, a few questions about deck height:
My engine guy says that the stock comp. dist of 1.858" should be fine even though we are going to be decking the head/block some. Should I advise him otherwise?
is there any reason to take more off the head than the block or vice versa, or is it arbitrary as long as we arrive at the desired compression without valve clerance issues or piston to head issues? I dont know what the stock deck height is (piston to deck that is.)
GalaxieInline:1alrieml said:
progress:
-crank turned .010
When racing my 223 I couldnt keep from breaking the finger pivots of the stock 9 1/2 inch clutches, so often that I then went to a Big Ford truck F500 / F600 flywheel and 11 inch clutch which solved that problem.
Sorry I don't know where your going to find the 223 .080 over Rings except in the old cast iron type. To the best of my knowage the Chrome type Rings aren't made In more than a .060 oversize now. Though you maybe be able use some from a Y Block V8 like for a 272 V8 stock it's real close to the same bore size as a 223. But bored .080 over thats about 3.705 then you might be able to find some file to fit rings, in that case you can try John Mummerts Ford Y Block site, he lists Cast and Forged Pistons and Chrome Moly Rings for a 272 in over sizes up to .060 over so he might know of a sorce for the .080 over rings (I don't know if they are going to be the same ring land width though you will need to call to find out) he also used to carry the rebuild parts for the 223 engines too and has a head porting service. Check out his Aluminum Y Block heads for some tips on what works with the Y Blocks and 223 heads. http://www.ford-y-block.com/index.html
Some people have used the above 272 Y Block pistions in the 223 by using an early 300 Ford six Conecting Rod too (.912 pin size). Did you actually need to bore Your block out that far over size? If not it might be better to keep hunting for the Pistons in .060 or under oversizes.
I don't remember what the stock block height was my best guess is it's around 9.70 inches from the crankshaft center line to block deck, for best accuracy have your machinist check that measurement for you. The stock pistion deck height is going to be determined by the pistons compression height distance of 1.857 plus 1/2 the crankshaft stroke of 3.600 (equals 1.800) plus the connecting rod length center to center is (6.250 to 6.252) added togeather is about 9.907 for shortest Rod lenght and up to 9.670 for the longest then this is subtracted from the blocks height (9.932?) to give you the piston top measurement to the top of the block (down the bore). I also think that stock the Pistons are about .025 to .035 down the hole togeather with the steel shim head gaskets being about .020 thick that they used the quench distance was about .040 to .060 but that was a long time ago to remember so I may be wrong on that measurement. Anyway I usally measure what the stock piston top to block deck height measurement is before beginning the engine disassembly to use as a working measurement to go from.
Yes the deck height is quite important, in that if you are going to use the new style composite head gasket the Quench distance is then about twice of what is was with the stock steel shim head gaskets that the 223 would of originally had. Yes in my opinion it is better to keep the quench distance tighter now days at .035 to .050 so this is much better then to just cut everthing off the head to get to your desired Compression Ratio. With the typical FelPro Perma Torque head gaskets crush distance at approximately .050 then we would have a minimum deck height for better detonation resistance when raising the compression ratio much over stock. Besides decking the block to attain this you could have also offset ground the crankshaft (Rod throws) to gain a little more stroke length too or also maximizing to Rod lenght too sometimes you can use oversize bushing so they can be all matched in lenght too and as long as possible and this to can keep from needing to deck the block as much. In any case the blocks deck should be trued and squared up so that it is parael to the crank centerline too. If you are to be using a steel or copper head gasket then it's a different story all together on the quench height. Good luck on your 223 build up! (y) :nod:
:hmmm: Galaxieinline, I was just wondering how your doing on your 223 engine build up? :thumbup: :nod:
block and head are at the machine shop. Going to have harden seats and new valve guides installed as well as the valve themselves worked. Had three blown rings, two actually came up through the top of the pistons. No damage to the cylinder walls. #4 cylinder is slightly out of round. Going to have the block bored .03 over, re-decked, of course new bearings, the mains honed, crank ground some. Cam looked good. My machine shop has the ability to re-dress the contact surface on the lifters. So we will go back with new plugs, oil pump, bearings, rods, pistons, rings, timing set, lifter rods, valves, valve seats, guides, seals, and gaskets.
I'll keep y'all posted
Updates would be great. Although The content is a bit above my head, and beyond my wallet,I have been enjoying and learning as you guys discuss options Thanks
Well update on the rebuild.
Need to sleeve all 6 pistons. What we thought was a motor with 50K original miles actually turned out to be a motor that had been rebuild and bored out .06 over. SOOOOO ... we cross checked the numbers and it is the original motor to the truck, so I decided to save the motor. We are going to sleeve it and bring back to standard.
Valve job and new seats on the head, full rebuild kit and sleeving the motor back to standard. More $$ and Time than I expected but it'll be worth it.
Keep everyone posted .. and I'll add some pics of the re-install. :beer:
:unsure: .060 over isn't all that bad on these thick cylinder wall 223 blocks. Many of the 223 engines back in the day were bored out to .120 over on a rebuild. Call Egge Machine in Santa Fee Springs, California to see if they can still make you a set of .080 over (or more) oversize Pistons and Ring's. Good luck on the rebuild. :nod:
https://egge.com/kit/f223m55-60/
Project moving a touch slow due to winter and being busy with my business and I promise to keep this updated. I got her all assembled and back in the car, but we had an oil leak at the front of the oan by the timing cover during break in. Out came the motor to address the oil leak...cant find a cork pan gasket anywhere, anybody have a source? All I find are the rubberized paper ones andI cant get them to seal!
Anyway I ended ditching the cloyes chain and getting a rollmaster double roller Y block chain. I advanced the cam 4° for good street measure. I need to surface my headers as they are warped (crappy QC from clifford, wouldn't expect any less these days from them.)
Im thinking about welding up some threaded holes to put some wideband O2's in each header to help with carb jetting and tuning this spring.
Ill post some pictures and some explanation of all the machine work done.
More pictures
Congrats on the build. Looks great.
Ps where did you get that valve cover, it looks taller than the one on the 223 in my 63’ galaxie?
Thanks,
Jonathan.
Jonathan, my valve cover is the stock cover that came on the car. I believe they changed in 62 or 63 over to the "FORD" block letters and had bolts around the parimeter of the head VS the previous years which were held on by 2 bolts on the rocker risers. I had my valve cover, timing cover, side plate and oil pan chrome powder coated at our local powder shop. They dont look exactly like chrome...more like clearcoated polished aluminum...which is COOL! It also cost a *lot* less than chroming.. I was quoted avout $1500-$2000 to have those parts chromed...powdering came in just under $350 or so. I had my headers ceramic coated at the same time in the same batch :)
I just got my headers back from a friend who works at a large machine ahop and he trued them with a bridgeport. God.....they were HORRIBLE. If anyone is thinking about purchasing headers from Clifford, I would check the flange when they arrive immediately and reject/send them back and ask for a different set if they are as bad as mine were....I had spots that were .050-.100 off!! I never could get a good seal from the get go and had blowouts at cyl # 2,3 & 6. It was obvious that whoever welded mine together at the factory used too much heat on the #6 flange as it was visibly warped inward. Really, for $500 you should get a set of headers that at least seal for a while when you torque them down.
Anyway....cold weather and all, I've been finishing the inside of my garage. The header surfacing was one of the last major things I needed to do before I put her back in the car.
Now I need to figure out the clutch issues:
SO.....anybody have any information on which flywheels and clutches fit in a passenger application? I had assumed that the Y block 11" pattern flywheel would bolt right up (which it did) but I think I have clerance problems with the 11" pressure plate hitting the bellhousing, as I found a rather bad rotary burn mark on the inside of the bellhousing and was having some issues with clutch disengagement.
I know the Galaxie/300 in '63 was available with a HD 11" clutch behind the 223 as an option for taxi's and police cars. It was also available in the trucks as a HD option. Im *assuming* the truck bellhousing was different than the car, but am not positive, was the car bell housing different than the 'standard' 9.5" clutch housing? Does anyone have any ford part numbers to cross check this?
Thanks again!
Thanks for the advise, perfection was of no help to me. I ended up only being able to squeeze (just BARELY) a 10" B&B style on a re-drilled flywheel. 11" WILL NOT FIT inside the 63 FORD car bell housing! The 11" diaphragm clutch even hit the housing and ground grooves into it/damaged the finger rivets.
Once I had the clutch squared away, I finally for her running!! I took it to a local shop that had a dyno and paid for 3 hours. We found the main jets on the weber had to be resized to .055 jets instead of the stock .045. The idle jets needed increased as well to get it to idle correctly.
I've come to find out that the "bolt on kit" that clifford sells for this motor is a total joke...it will not run correctly (rich no matter what you do) without changing the jets. Maybe it is a difference in sea level altitude out there? We are at about 700' in Indiana.
My results were quite disappointing after all the money I've spent on this project and I'm wondering if anyone has any advice on what went wrong here:
My timing ended up at 28° at 500rpm and 38° all in with no detonation past 5500rpm. We lost hp either direction so that's where we settled.
My AFR is about 12.5-12.7 at idle, 13 or so in the midband.
My torque bandwidth was excellent, starting at 800 rpm and not falling off until 5500 rpm. Torque results were a fairly constant 157lbs at the rear wheels....what???? Stock its rated at 205 at the flywheel...shouldn't I be seeing a fair bit more?
HP started at about 75hp at the wheels around 1k rpm and peaked at 110 @ 5600rpm and continued to rise, though we dared not take it past that. Again....138hp stock, I'd imagine about 100 rwhp from the factory...tell me that all of my mods weren't only good for 10hp at the wheels? I saw a youtube video of a 58 truck pulling 98hp stock at the rear wheels.
Keep in mind this is about a 4000lb car, but the only accessories I have are a water pump and GM 12si alternator and all run through a 3 speed manual. Shouldn't be a huge amount of drivetrain losses.
The car does get up and move pretty well after the rebuild, great drivability and torque band, certainly a thousand times better than before....but I cant help but feel that the difference is because the motor was so worn out she might have been lucky to muster 40hp to the ground with the previously weak compression.
So whats going on here, thoughts as to why the dyno pull was a lot lower than expected? I was expecting at least 175-200hp and 250lbs or more of torque...but it almost looks like its now putting out about stock numbers!
