excellent you might have to do a little bit of retuning to get the best performance out of it.
A Compression test will tell you a lot about the condistion of your motor too.
Basic tune up to get your Mustang running its best follow this order for the quickest way to get tuned up and also these are the stock general tune up specs!
1. Set your Spark Plug Gap to .034 and reinstall them.
2. Now set the Point Dwell to 39 degrees.
3. Next set your Base Timing to 10 degrees BTDC for a manual trans with Vacuum line to the Distributor disconnected and plugged. Reconnect the vacuum line to the distributor. This is good starting point for a stock 200 six engine, but you can also try 12 degrees later to see if your engine likes that.
4. You should verify that the float level setting (the wet fuel level) is correct on your Autolite carb.
5. Next set your carb mixture setting to the lean best idle, the basic setting after a carb rebuild is 1 1/2 turns out. Then with a tach hooked up and the engine is first warmed up to normal operating temp. Turn the mixture screw in until idle speed drops slightly then turn the screw out until you reach its highest idle RPM then turn screw in 1/4 turn (to Lean it) this is your lean best idle setting.
6. Last set the Curb Idle RPM (500 to 600 RPM).
7. If you get the choke parts hooked up and working then it needs to be adjusted or also checked too. Auto choke cover is set to about 2 index marks past center Index Mark on the Rich side. And with the fast idle screw set on the fast idle cam index Mark (>) you will want to adjust screw so the Fast Idle is from 1200 to 1400 RPM or at just a high enough RPM so that when the car is still cold it will drive without stalling. Check when the engine is warm up good to operating temperature that when you blip the throdle that it resets the choke linkage and is coming off of the Fast Idle cam and that the choke blade is to fully open. Recheck this setup again after the engine is compleatly cold to see if it is working properly.
For the best results I usually repeat steps 5 & 6 just to verify that the carb RPM settings are right on. Good luck
