So the car was running fine but then and it sat for a month. Now it is not getting fuel. ie when I pull the throttle linkage manually, I cannot see the fuel squirt in. I thin that main needle valve is stuck up? Checked fuel line and it is filling a cup, so the fuel pump must be fine. what to check? I can dribble a little fuel directly in carb throat and it starts then is not gettgin fuel, stalls. Any chance it is one of the check balls, counter weight? What to check?
Unfortunately it is the 1101 which does not have the removable needle seat. The needle valve itself has a very minor indent on the taper portion near the point.
My duraspark II ordered but I want to make sure I have the fuel side of things working well first
