Not really much to update, (although I expected to be able to do so).
I have the pan on the block, and the engine and trans back in the car to test fit the pan, and fabricate the mounts for the engine and trans.Testing the pan for leaks is still yet to do, and that turns my thoughts as to how to do that by filling it w/ either mineral spirits, or water. I still gotta weld a drop sump into it(like 2"), and add an anti slosh baffle, as well as the T/C drain back, and dipstick tube fitting. The real problem w/ that is the filler strip is above the semicircles that are the front/rear timing cover/rear main seal areas. How to fill the pan to get it up high enough to ck that before it spills over those areas.
The pan is bolted to the bare block again, and is in the engine compartment attached to the 4r70w. I am in the process of trying to make the stupid trans fit (which it don't, I had to cut part of the drivers' side tunnel), and building the trans crossmember similar like I did on the red car below.
This makes sense to me, more so than why use the stock mounts and have to build a hump for the exhaust to get by.
It requires that I plate the floor from inside w/ a 6 x 8" piece of 1/8" plate and stick those two little ears down through to bolt the cross member to. I'm making the one for the the Gila Monster out of 1/8" plate as well w/ side rails to add strength while keeping it as lean as possible, but as usual, I spent several hours and have little to show for it.
The good news is that I was able to use the 200 rubber fox mount, mated to the steel 250 block mounts. ( w/ a minimum amount of.........uhhhh....cobbling.) The engine sits where I want it, but the mount pad angle is different on the k member. I had to insert 1/4" spacers at the bottom of the block mounts to force the mount pads to angle up to meet the difference.
The trans tunnel required a driver side tunnel-n-dectomy for the shift linkage and connector to adequately clear w/o the dreaded rattle and thump that would've occurred had I left it alone just jammed against the floor. The whole thing is still a day away from being done, and after yesterday,..there's no wayy in hell I'd be able to get away w/ spending another day in the garage w/o the wife b itchin' about it,...so, it'll have to wait till another day.
** edit. It occurred to me that Nobody here knows what the Gila Monster is: My project Fairmont:
and the "red car" My last project 89 fox mustang:
This was my last car, totally built be me w/ an all steel front and rear end to pay homage to a 60's theme using 89 fox notch as the platform...
In hindsight, mounting the engine and trans in the current car is kids stuff.
