Well I just purchased a '75 250 that I had asked about on a previous post. Now that I have it, I would like to know what can be done to it to achieve 150hp. Actually I would prefer 170hp but I could live with 150hp. I have searched this forum quite a bit, but I find most people are shooting for higher numbers and therefore getting into more complicated stuff. By the way, this engine is going into an Early Bronco 4x4 so mid range power is what I'm really after. High rpm doesn't do me a whole lot of good when fourwheeling.
Is it possible to reach 150hp while maintaining stock compression ratio? Can I do it without pulling the head and having it worked on? I do not have to worry about smog equipment, and I have already yanked most of it.
This engine currently does not have a carb, so that is the first thing I will need to find a replacement for. So if any gains can be made by an "other than stock" carb, I need a new one anyway.
Also, I ran across a post that mentioned switching to a pre '71 timing chain set. The post gave the napa numbers as being S414 for the cam gear, B415 for the crank gear, and 9363 for the chain. When I did a search on napa I came up with S415 rather than B415 for the crank gear. Is this correct?
Now slightly unrealated, I am planning on switching this engine over to a made from scratch fuel injection setup in order to help with fourwheeling. I know that the intake log is less than ideal for making hp, but does it really affect anything when we are talking 170hp or less? I had originally planned on having the log machined off for my efi setup, but if it can feed 170hp I wouldn't need or want to. I know little about flow characteristics, so I do not know if that is something that comes into play mainly at higher horsepower, or if it is holding the engine back at all levels.
Lots of questions and I look forward to your answers,
Morgan.
Morgan.
