My '66 is driving me crazy...haven't had this tough a problem in a while. Posted on this about two months ago and appreciate all the feedback to get me to this point.
Problem: It spark knocks under load and is the worst under moderate throttle- WOT reduces it.
I have done the following:
New harmonic balancer
Replaced distributor with original style Load-O-Matic from Mustang supply place (new vac advance, new points/condenser/rotor)
Set timing at 12 deg BTDC
New plug wires
New plugs
New fuel pump
New fuel filter
New PCV valve
Rebuilt carb (Motorcraft 1940 w/o spark valve)
Radiator rodded out- cleaned
Thermostat replaced with 160 (was 180 and car got very hot in traffic)
6-blade fan
Sea-Foamed the car twice to clean out carbon (seemed to work but after time no change)
No obvious vac leaks but haven't done too much checking
Car is approaching 200K (90K on rebuild) and it does seem to burn some oil but when it burned tons of oil 20 years ago it never did this.
Spark knock started when I replaced the vac advance unit.
Otherwise it starts and runs fairly well- the new fan and lower t'stat really help keep it cool in traffic compared to how it used to be.
Any ideas? I am out of them!!!!!!
New plug wires
New plugs
New fuel pump
New fuel filter
New PCV valve
6-blade fan
