candyapple66
Active member
Hi all-
I recently tried to remove the rear main seal with the engine in the car. It is the original rope seal. I tried using the chinese finger type remover on the top part of the seal that is in the block and pulling it out with the spiral tool that they give you. Needless to say i only ripped a little chunk out of that one side. So the rest is still tight inside the block.
Should I take the engine completely out, put it on a stand, remove all the main bearing caps and see if the crank can drop down. Will the crank even drop down at all? Can this be accomplished without removing the timing chain and all the bells and whistles? Im going to put a modern rubber seal in instead because that rope seal looks like a pain to install. I will remove the pin in the bottom cap that is there for the rope seal.
Id prefer to not have to tear the whole bottom end apart, I want to make this as minimal an effort as possible because the engine has 107K miles on it and everything is really top shape and I just had the head completely rebuilt.
Hope to hear from someone who "knows" or has done this type of seal before.
