dzertracer
Here is the start of my Megasquirt project. The plan is to upgrade my 1987 F-150, Factory EFI 300 to a Megasquirt MS-1 3.0 controlling fuel and spark. I also changed out the stock 14# injectors to 19# and an adjustable fuel pressure regulator. For those interested you can check out the build up and specs of my 300 in the 300 forum under "my new 300 baby build".
The new 19# injectors and adjustable FPR. Notice the black piece holding down the FPR. The original mounting holes don't work with the Mustang FPR. I made a steel plate to sit on top of the regulator and clamp down. It uses the three factory threaded holes with 1 1/2 long allen screws.
My new yellow top injectors installed with the FPR.
I finished putting the intake manifold and everything else back together tonight. What a PITA it is just to change out the injectors!
Tomorrow I will install the MegaSquirt and the custom harness into the truck.
On the left is a Ford computer, with the computer board removed, a new adapter board installed and connected to a custom wire harness. This allows the MS to plug into the factory wiring. No hacking up the factory wire harness! The small green computer board in the middle is a testing board that plugs into the MS. The black box on the right is the MegaSquirt computer (insert Angels singing).
I have also installed a Innovate LC-1 wideband 02 sensor with a digital gauge mounted in the cab. No pics yet. This will greatly improve the time it will take to program the MS.
My main goal is to get the motor running perfect. The factory computer has always had problems with the idle, and top end. Good enough to drive everyday, but not perfect.
I am also hoping to get the truck to pass CA SMOG. I failed NOX last year. With the MS I have to capability to change everything! Spark and fuel changes are all done with my laptop inside the truck.
I will keep you updated.
