Hey Everybody...I like following other builds so much, I figured I would start my own.
I have a 59F100 with a worn 223cid, 1bbl, LOM distributor, 3-spd standard on the column, and a 3.73 rearend that needs rebuilding.
I got the truck with a "hardly running" engine that had "no pwer". This was very true...I found loose valve train bolts, loose rockers, no vacuum signal to the "load-o-matic" (LOM) distributor advance, oil soaked and carbon fouled plugs, and leaky exhaust and intake gaskets...and thats about all....
I fixed all of these problems and the truck started with ease even on very cold days and ran very smooth and very quiet...however, it still had no power...it bogged severely with any type of load (common problem from what I have researched). I left off last spring (before I was deployed) rebuilding the carb which was ABSOLUTELY FILTHY inside and trying to piece together the stock throttle linkage with parts from one of our members here (my original parts were missing when I bought the truck).
I have a four week vacation coming in November and have been trying to mastermind a plan to get the most out of my time and stick on a budget at the same time. Here is my plan....
Rest of your build plan looks good
