See viewtopic.php?f=1&t=70844
The top up position gives a carb a 150% enrichment, about 9:1 air fuel ratio, while turning it back makes it a normal functioing carb at some point. So you can remove the choke, and use the first third of movement as cold sart enrichment, and a working portion as a closed loop stoich control, and then t rest an open loop performance mixture. Each portion can be cruise controlled within an EGT or single O2 sensor stricture. The maker used old Marvel Schelber tricks in his Ellisons injection, and the Holley 2300 series has the worst roosters tail around, and adding the Tom McNeilly kit kills two bad birds (turbo charge density air fuel control and bad mixture distirbution and too large atomisation fuel ball micron sizes over 70 microns) with one simple 150 US dollar stone.
Love what your doing.
			xctasy":18mj77f5 said:All you need is some Area 51 Technology!. You have no choice but to use the stuff you have, your under carb adaptor you have, the carb you have, and take the carb to a machinist and have him shave off all of your existing carb's choke air horn and carb mounting flange so it ends up like the ones on the outer Chrysler 340 and 440 six pack Holley carb below.
Then use an adjustable main jet to operate cold start enrichment.
There are two types, but I'd recomend the one the Mazda Rotory guys use, sourced from Tom McNeilly tomcn@earthlink.net for US $150 dollars excluding post and packaging.These are throttle leaning devices used for light aircraft
Tom McNeilly
14001 East Williams Field Rd.
Gilbert, AZ 85296
International phone number is +1-602-899-7613
He's in Arizona, USA. Almost nothing any good comes from anywhere else! Hear that Azcoupe?
Northwest Aero Products also has them available. They are at
13812 179th Avenue SE
Monroe, WA 98272
International phone number +1-360-805-8183
Call displayed telephone number to ask for respective email address of Northwest Aero Products.
DetailsHere is some information about the Holley mixture control kit. It is best suited for a two barrel 350 or 500 CFM Holley carburetor. However, the unit has been successfully used on large four barrel carburetors. The mixture control WILL NOT fit other makes and models of carburetors! The unit replaces the fixed main jets with a rotating valve that is remotely operated by a push pull cable. The unit will go from total idle cut-off to overly rich by rotating the shaft, while the engine is running. Installation is very simple with step by step instructions provided.
Due to the outrageous cost of materials and the inflationary state of our economy,the price of the kit has recently been raised to $150.00.
The mixture control body is CNC machined from 6061-T6 aluminum which is alodine treated, the shaft is stainless steel and the screws are plated steel.
The first picture is what comes in the kit. The mixture control plate is in the background with the accelerator pump extension arm., power valve block off plug, and installation bolts in the foreground. I also include a set of three gaskets which are not shown.
The kit
An example fitted to a 4-bbl carb with its choke air horn still attached
