mysavioreigns
Car won't start - I can't figure out why I'm getting no spark (but I do have gas)
My setup is a DSII distributor with the HEI 4-pin module. I bypassed the pink resistor.
Here's my deductions:
I turn the key to ON:
1. "Switched" items, like the windshield wipers, now work, so the ignition switch is good
2. BOTH terminals of the coil are getting 12V
3. The B and C sides of the HEI module (which go to the 2 sides of the coil) are also getting 12V
4. The W and G sides are NOT getting 12V. Perhaps this is because you have to hit START for it to get the 12V?
5. None of the 3 terminals on the distributor are getting 12V (obviously, because the W and G aren't either)
I had it running a few days ago, everything was fine, came out later, wouldn't start. I checked a wire and it was kind of loose, so I put a new terminal on it and it started up again. Now it's back to no spark AGAIN and I can't figure it out.
Please ask lots of questions to help me figure this out
