The fan? THe engine fan? Mechanical or electrical? If its the mechanical engine fan sounds like you got something going on in your wiring, solenoid, or ignition switch.
mysavioreigns":3ptf3qc9 said:Man, you guys missed a show....we were moving down the street Saturday, and the car wasn't working, so 7 friends and I pushed it down the road (although it only took like 2 people, lol). We got some hilarious stares.
I got a spare working coil, I'm gonna give that a shot tonight.
MustangSix":2grf8umx said:I don't think you will see anything from the W-G side of the module without an oscilloscope. It is only sensing the alternating current waveform coming from the pickup and that is only a few millivolts and only when the reluctor passes by.
MustangSix":2grf8umx said:The only other thing I can think of is to check the pickup coil. There should be continuity if you unplug from the module and check between the orange and purple wires. There should not be continuity between either of those wires and ground.
mysavioreigns":3l62nopu said:The pickup coil is the piece inside the distributor, correct? If so, I'm not sure if that's the problem. I get no spark coming out of the ignition coil, which the pickup coil is not a part of.
MustangSix":1jxg0bx7 said:mysavioreigns":1jxg0bx7 said:The pickup coil is the piece inside the distributor, correct? If so, I'm not sure if that's the problem. I get no spark coming out of the ignition coil, which the pickup coil is not a part of.
The ignition coil fires as the magnetic field collapses when the negative side goes to ground. If the pickup coil is dead, you won't get a spark because the module won't know to turn off the current to the ignition coil.
You an test the coil by hooking up 12V to the + side of the ignition coil, then shorting the negative side to ground. Every time you make/break that connection, the ignition coil will fire. That's how points work. If you can get a spark that way, you know the problem is either the module, the pickup in the distributor, or the wiring between them.
MustangSix":1lq6t4ml said:mysavioreigns":1lq6t4ml said:The pickup coil is the piece inside the distributor, correct? If so, I'm not sure if that's the problem. I get no spark coming out of the ignition coil, which the pickup coil is not a part of.
fordconvert":1dxhatft said:Is there anything else connected between the - wire of the coil and C on the module? There should not be, that should be a single wire that only goes between those 2 places.
Hook a spark plug up to the coil wire and then take the wire off the C on the module and touch it to ground for a second, (key on) you should get a spark from the plug (also a small one where you ground the wire). That tells you that the coil works.
With the C wire still off the module hook your test light between B & C and crank the engine, your light should flash. IF it does module is working.
Hook the C back up and it should work.
