Hello all,
For the past five and a half years, my dad and I have been restoring a '64 Fairlane with the 170 and 3 speed. I bought a Sealed Power solid lifter camshaft kit for the engine. About 2 nights ago we started to degree the camshaft and came up with an intake cycle of 253 degrees and an exhaust cycle of 235 degrees. I did some checking and all the camshafts I found had either indentical cycles or a longer exhaust cycle. Here are some more of the numbers. I apologize in advance for anything repetitve since I'm new to this. The intake starts to open 28 degrees before TDC on the intake stroke and it closes at 45 degrees after BDC of the intake stroke. The exhaust starts to open 55 degrees after TDC on the power stroke and it closes at exactly TDC of the exhaust stroke.
What we are wondering is where the intake valve should start to open in relation to TDC of the intake stroke. I checked out Sealed Power's website and could not find any listing for a camshaft for the entire Ford small six family.
I'm not sure if these extra numbers will help but I thought I'd post them just in case. It's bored .030" over and the crank is 10 under. I have the 2.77 "crashbox" tranny with a 3.50:1 rear. Factory specs list 6 degrees advance max on the distributor yet it backfires (along with some loud pops) during decel. When running 14 degrees advance however, the backfiring is gone but I have basically no vacuum at idle (about 750-850 RPM) and I get major ignition breakup around 3800RPM.
Any help would be greatly appreciated. Thanks.
