air conditioning and header
Where are the pics posted of the header install when you have air conditioning. Specifically the aftermarket air conditioning.
I know I need to modify the alternator bracket by adding 1 or 2 inches and redrilling the bolt mounting holes.
I've searched all this site but the posts are getting quite a few in number.
Mike, have you had any problems with not being able to keep the a/c belt tight enough in that configuration. I did and thought I would solve it by going to a double pully, running both belts around a/c and dual pully alt. Still having problems with belt slippage. I think I will try running one around the a/c and another around the alternator, maybe the belt is not catching enough of the a/c pully in that over under configeration.. I have the Sanden compressor, it does a great job cooling, just wondering if it's too hard to pull for some reason.
Okefenoke,
The rotary Sanden compressors use less HP than the old York & Tecumshe compressors.
Doug
