Hi folks, I have an 1100 on a 1963 170ci in a 1963 Falcon, 2 spd auto, manual choke. Engine runs great, good idle, plenty of power for the 170. My nagging and annoying problem is the percolating fuel when the engine is shut down. Has done this since day one. It doesn't come out the top, just down into the intake making for a hard start condition. I have the 3 check balls and 1 weight positioned according to the diagram and my float is now so low that if I take a sweeping turn to the right(think freeway exit) it will lean out. Engine starts fine when sitting over night or more than an hour after shutdown. I have the original water spacer under the carb with no additional stud length for additional spacers. Also the vent valve rod has been disabled in the open position with no effect but to evaporate the fuel bowl in a couple of days. Is there anything I should look into? Or is this just a quirk of the 1100 to live with. I have tried the search function but was not successful as you can tell Any help greatly appreciated.
Thanks, Steve.
Thanks, Steve.
