I didn't think that jet holder was supposed to be adjustable either. However, when it is all the way in the engine will not run without the gas pedel depressed at ALL times. The minute I lossened it up about a turn, the idle completely smoothed out. It hasm't ran that good in years.
Even when it is out 1 turn, there is still tension on it
You were right about the blue arrow, it is actually behind the choke assembly. There was no way to get everything in the picture.
The lean idle mixture is supposed to be somewhere between 2 to 1/2 turns out (or something like that, I would have to dig up the documentation). Any more or less and they suggest rejetting.
I will play with it more and try what you suggest about tightening the holder and loosening the mixture screw, but I had it that way earlier. I had the adjustment all the way out and it would not idle. We'll see.
