With your cam, the 272° is total duration. You can have an "aggressive" cam that opens up quickly (aka steep ramp) or a gentler one that opens more slowly. Yet both have the same "advertised duration".
Information you need about the cam is generally:
Total duration (Advertised duration)
Duration at 50 thou
Max lift (preferably of cam lobes, not valve lift)
Intake lift at TDC (lift at TDC)
Centreline or angles at opening / closing
Operating (power) range
Recommended idle RPM (which may note if a stall converter is required)
Clifford should be able to get that information to you. If not, there's more than one way to skin a cat.
Jumping back a step, the reason I mentioned your ignition and electricals is due to experiences with these issues. Sometimes, a rebuilt unit can be way off what you need. It may be assembled wrong, or have wrong components. That was my concern with the distributor.
As to alternators - I have seen them work fine at low engine speeds, then with warming up and increased load, the output degenerates and the motor coughs, splutter erratically and fouls plugs (leading people to say the carb is running rich!
). Proper testing procedures on each of these is the only way to be sure (unless you're experienced in either field). Lifetime warranties are well and good, but a diagnosis is sometimes worth more.
Adam.
Duration at 50 thou
Adam.
