Okay, here's the story (back ground information).
I completely rebuilt my 200 just a little over a year and half now. Everything was fine for the first couple of weeks and then I starting hearing a ticking sound coming from the front of the engine. I purchased an engine stethiscope to try and pin point the cause. Well, after trying several different ideas, mostly suggestions from you guys, I was able to pin point it to the exhaust lifter on the #1 cylinder. Surely lifters don't crap out that soon but sure enough when I pulled it out, the lifter had collapsed.
So, out with the old and in with the new. Once I changed out the lifter I reassembled the motor and life went on - until about three weeks ago.
Sometime in the past several of you helped me in determining my compression ratio and came up with something like 7.7:1
This didn't suprise me considering a previous owner had swapped heads with a later date and didn't consider a mill. Anyway, so I thought it was time to get it right, or at least as close as possible.
I got the head back this morning and reassembled the engine, again. Everything went smooth. As a matter of fact, the engine fired right up and ran the smoothest I had ever seen! But here's where it goes down hill again.
Like better I'm getting a ticking noise. Not just from one location - the entire engine it ticking!
I adjusted the timing a few times and have it currently set to 10 deg. BTDC.
It sounds like the rocker arms are going to explode into a thousand different parts! Seems like most of the ticking is coming from the head this time and not the block.
Here is what I had shaved from the head - .055
The machinist said he didn't want to do the .070 I had requested because it looked like someone already milled it before.
How would he know?
So, with a stock engine and '77 head milled to .055 (?) and a Fel pro gasket I should be somewhere around 9:1, right?
Help, please?
-Chris
P.S. Before the mill, the combustion chambers average 61cc. Oh, and I still have the stock rocker assembly.
Help, please?
-Chris
