stangman196700
Active member
ok i have a 67 stang with a 200. The radiator blew a hole near the top where you put the cap on it. I used a hammer to shut it back to the way it was and i was wondering if that expoxy style radiator fix stuff actually works because i want to get it but am very low on cash as is and wonder if this will fix the problem. I just need the car running since im moving and need to move it about 5 mins away. ill try to post a pic of the damaged area.
P.S when i tried to see if the radiator would work like this without the epoxy all the anti-freeze sprayed all over the engine bay. The hole is on the oposite side towards the grill. did it go to the engine bay because of the fan?
