I forgot to ask- Do you know which cam Jack put in this engine?
> Supposed to be a 272 (hydraulic)
Do you know what the CR is on this engine?
> From a previous thread, this was a mystery. The purported Jahns 10/1 pistons turned out to be AMC 258 STD pistons. From the calculations you provided it could be from 8.8/1 up to whatever milling and gasket variables add up to which I won't know til I open it up (Hopefully later not sooner...)
http://fordsix.com/forum/viewtopic.php? ... highlight=
I used a piece of old hose as an adapter on the lower radiator bung and got the much shortened upper hose to fit the larger pump outlet.
I also forgot to tell you that my 250 is not peaky or boggie at all. It pulls strongly from 1,500 on up.
> Now that's what I want to hear!
Last carb I tried on the 170 was a 7448 350 CFM 2300. It ran rich but may prove useful on this engine if the little Holleys don't. Did you check out the link to fabbing traction bars?. I liked the way he explained the physics of it .
I got the 90's 5.0 starter in the mail today and will work on that and the pusher fan
next.
Thanx for listening
Powerband 8)
