rommaster2
Well i'm currently planning on taking my sisters 2 barrel holley off her 289 (shes replacing it with a 4 barrel) and using it for my 200.
I am wondering if i'd need to switch over to a cable throttle or if the regular linkage will work without any serious modification. I would be using an adaptor (not sure from where, any suggestions would be welcomed, links especially
Also do you think standard jets would cause a problem? Or do you think i'd be fine without changing them? (i'm gonna get the item number off it tommorrow, as i need to get a rebuild kit for it anyways).
Also how easy\hard is it to get a throttle cable? Is there a kit i can buy? Would this also help my quest in getting a floating pedal cause i hate the one thats in the floor.
