so i was working on the granada today the tranny has been acting up not wanting to stay in high gear i figured id check the vacuum at the modulator, so i decided to set the timing to stock since i didn know where it was at but i knew it wasnt right. it was off of the indicator id say 16-18 degrees (stock is 12) so i set it right checked my vacuum 21 inches on the manifold at idle and 18 at idle at the tranny took it out for a short ride(it started raining and i found out i need wiper blades bad) and it shifted smother into all gears and stayed in high anyone out there that can explain how this works?
