A couple of questions. I tried starting a new engine (200c.i.) and the engine is cranking over but won't start! It is getting gas but, I have no spark from either #1 spark plug wire (only one I checked) or from the coil! Checked the coil (old coil, but working before) with an ohmmeter and the resistance was around 10,000ohms; the manual says 4,000 to 10,000 is what it should be. The reason I posted on this thread was that I have had a similar problem as "Ochretoe" with my vacuumn bisquet too close to engine block and not allowing any further advance than what the manual calls for (6 degrees BTDC). So with the engine in the top dead center position ( I could see the top of piston in the cyclinder) I lifted the distributor out of dizzy hole, and keeping the rotor pointing at the #1 spark plug wire in the top of the dizzy, I moved it several gears until it would sit back down in the dizzy hole! My neighbor doesn't think that you can do this; that it will throw off your timing; he thinks maybe that is why it won't start? Comments please! He also thinks I could be off 180 degrees and that maybe that is why I am not getting any spark?? Sorry for the long winded message; I hate to crank the engine over too many times without it starting since it is a new engine! Thanks!
