Carb differences
According to Langdon's, it's the linkage that makes the HW 5200 most suitable. I personally like the way the Carter has a place to screw down a center mount air cleaner. I found a simple solution to the linkage problem, without bellcranks. See the HW Jetting Sticky.
They're mirror-images of each other, and the Holley/Weber is the one to get for a FordSix. Unless you want the throttle pulling from either the front or the passenger side.
Carter = Weber DGV
Holley = Weber DFV
