Just curious,
Is there any benefit to put a larger ratio rocker assembly of a stock engine? My only mods are a 32/36 and a HEI. Would i only notice a difference if the HEI was curved properly? I was just wondering since i saw 1.6 ratio rockers on vintageinlines. I have an adjustable set on now, im assuming probably from a 170, im running a 65 200 with a 66 head.
My plan would be to swap out the rockers when i change my valve cover since im pretty sure its bent up and it wont quit leaking after so many gaskets. That would be the only thing i do, just the rockers and the valve cover. Is that ok or would valve spings need to be swapped to for that?
Thanks guys
Ryan
Thanks guys
Ryan
