My charging system on my 200ci has been giving me problems. I've been trying to find the cause for the last month or so without any success. It hasn't been a total loss, however, because I've been learning a lot; mostly how NOT to diagnose a charging system. Here is what I've done so far.
The car died on me one night (of course at night right at the end of an unlit exit). I took the alternator into Autozone and it tested out OK. So I replaced the voltage regulator. I did this against my better judgement because both the alternator and the regulator were replaced when I bought the car.
Long story short, I charged the battery, drove the car around for a couple hours, then it died on me again. At this point I jumped the car and checked the voltage at the battery, which was very low indicating that the alternator wasn't charging.
I got the car home and let it sit. I started it up the next day and everything was charging fine. So I am only having issues when the engine is hot. I figured I had an intermediate issue in the alternator and replaced it (again, against my better judgement).
I charged the battery and started it up. I was getting 14.4V at the battery at idle with the new alternator (engine cold). I got in the car and drove for 30 min. The voltage was now 14.2V. I then drove home another 30 min and the voltage was 12.3V. So I am still having the issue with the new alternator.
I did the following voltage drop tests at idle engine hot:
ALT OUT (fusible link) --> BATT+ : 0.5V
ALT CASE --> BATT- : 0.2V
The voltage drop on the negative side is good, although the insulation on the ground strap is pretty ratty with some exposed copper. I might replace that just because it looks like it needs it, but I'm getting good ground.
I was thinking my next step is to swap the battery? The battery was also replaced when I bought the car so I'm kind of done replacing brand new parts. What now?
Jason
Jason
