62Ranchero200
CZLN6":1vu3794v said:Howdy:
Ok, assuming an overbore of .030" with a dished 6.5 cc piston, a Victor head gasket @ .045" compressed thickness, cleaning up and smoothing the chambers and milling the head only enough to true the mating surface, and decking the top of the block .070" will yield a static CR of 9.1:1.
That will leave .053" deck height. That plus the .045" thickness of the head gasket will give you a deck clearance of .098". While this is way too much for ideal quench effect, it is way better than the .148" you started with.
Your probably asking why only .070" off the top of the block? Because that amount give you a CR very close to your goal. And, because I couldn't recommend removing any more material due to structural integrity and maintaining the depth of the head bolts. At this dimension you will still need to use hardened washers on each head bolt and you must verify that the head bolts are not bottoming out in its hole.
I'd sure like to hear more about the piston maker and possibilities.
Hi David,
I really appreciate you running those numbers for me. I like the approach you outline, and if I stick to using the large log head I'll probably use that approach.
A couple of notes:
I'm seriously considering using the aluminum head. Long story short, CI now does 2V conversions with furnace brazing, which requires that new valve guides and seats be installed after the furnace brazing, plus a three angle valve job for the best performance. That puts the cost of the 2V conversion at 2/3 of the cost of a bare aluminum head, and around half of the cost of an assembled aluminum head, depending on the options you choose for the head (most notably springs). The aluminum head has approximately 50 CC combustion chambers, which will directly enter into the CR calculations, but also I understand that detonation will be less of an issue with the aluminum head because aluminum transfers head more efficiently, and because the CI aluminum head has a more efficient combustion chamber design. I'm waiting for Mike to answer a couple of questions before I make my final decision on the head.
Second, I'm going to use ARP head studs - bottoming out the studs wouldn't be an issue like it would with bolts, right? Just a bit more stud sticking out on the nut end?
Thanks
Bob
