The idea is that you don't pick up much power because your alternator will be demanding more power from the engine. A puller fan on the engine side of the rad will cool better than one pushing from the front. A good 14" or better, a 16" would be ideal. Set it up with a relay and a thermostatic switch so that it only comes on when needed and turns off by itself.
Installing a fan clutch may be a better option as it will reduce the drag on the engine and you have a clean look, no wiring, and a much more dependable setup.
