I have a 250 head I need to shave .075. Anybody know what the going rate is? I checked a local machine shop and they quoted me $80 to do it. Does that sound reasonable to you guys?
It cost me $70 to my head resurfaced taking off .010. I wanted to take off a lot more to get to compression down but was told this. One it would weaken the head too much for the amount I wanted to take off and second it would eliminate the possibility of being able to do any more work on it in the future if needed. Also you have to remove a lot more from a head than you do from a block to get the same compression result.
You get more benefit if you zero deck the block and take just little bit off of the head.
I am completely rebuilding my engine so everything was already apart in this wasn’t a problem. If your just working on the head a not taking the whole engine apart this would be a problem.
To deck the block it cost me $152, $80 for the first .010 and $3 for each extra .001, a total of .025
This was with everything taken apart. If you have them take everything apart and put back together it will be a lot more.
