I have a '67 Mustang Coupe with the 200.
Recently, I've added a Pertronix Ignitor ignition, Pertronix Flame Thrower coil, new rotor button, plugs, plug wires, etc. and it was running ok. After a drive around the block, I turned it off, and it was hard to crank, like the battery was weak. I took the battery to the store I got it from where they determined it was a bad battery and replaced it under warranty.
I installed the new battery, and it cranked. Drove it around, turned it off and the same thing. Seems like the (new) battery is weak. It drags and drags until the starter is clicking, then absolutely nothing.
I checked the connections to the battery and the cables are hot to the touch. Not like melt the skin off your hand, but hot. I replaced both positive and negative connectors as they were old, thinking maybe there was a bad connection, and it's still hot, and still won't crank.
I think I've included all the information here.
If you guys have any ideas, I'd greatly appreciate it.
Thanks!!
Thanks!!
