cranks cranking around
what do they use for the cryoing if its only liquid nitrogen then i have acces to at work and whould be able to cryo the crank and rods.
id say its worth doing this to valves pushrods etc as well then.
i rembered some posts from a few years ago on here so i did a search and found this site off Seattle Smitty http://www.metal-wear.com
so i might give the cryo a go my self with works liquid nitrogen tank.
i think ill also lighten the counter weights off a bit.
so here's a question on the big end's they have the radius then a step up around the rod.
now i belave this is there to trap the oil so you have pressure around the big end
how much of it can i take off i think i could go down to about 40"thou or 1mm above the bearing and still retain oil.
also how much should shot peening cost ?
You thinking about bullnose and taper yonsy? Good choice, reduces drag by creating a boundary layer on the weights, but retains balance between the topend and bottom end.
can you elborate on the bull noise i think i miss worded what i was meaning.
on the big end off the crank where it was orginally cast and then machined for the bearing surface there is a step or ledge iam wanting to reduce this to a minium before i start drilling holes in the big end throws.
ive also read in here that you can over balance which as i take it is.
having heavyer counter weights then the piston conrod assemble needs and helps mid range to top end.
or the crank accleration.
8) bull nosing means to round off the leading edge of the counterweight to improve its drag coefficient. knife edging is similar except that instead of a round nose, it is a knife edge. you also want to change the aerodynamics of the trailing edge also.
so bull nosing is basicly tear droping the crank counter weights.
is there much you can do on the big end side
