Last week while trying to fix a rear main seal leak the tech found a thrust bearing had some of it's surface sheared off. There was a fair amount of movement in the crank shaft.
Pic
http://imgur.com/YTWraAj
Anyways put in a new bearing replaced the seal. Seems now the leak is worse and I get low oil pressure coming off the freeway to a light which I read is generally bearing that have gone south. I was able to find a replacement used motor locally but wanted to know if it was compatible with my car.
http://seattle.craigslist.org/kit/pts/5025775937.html
I know I would be swapping over my new fuel pump, dizzy and rebuilt carb. Is there anything else I should look at? Also I would love thought on how a thrust bearing would go out like that? The car does shifter hard when going into reverse, could that cause this?
Thanks,
Adam
Pic
Thanks,
Adam
