I got thinking today, If I get rid of the stock mech fan, I could mount the intercooler behind the radiator in front of the engine, but is this a good idea? I figure, I could use a fan in front of the radiator controlled with a temp switch. but I want to run EFI so I will need a place for a coolant sender and the original temp sender to begin with, are there any other usable ports I can use for coolant temp? could I tee off the block for coolant temp?
