mraley
Anyone......
I've heard that with the Carb Swap to a holley/weber that the fuel pump needs to be changed to a low pressure electric
If so, who sells them for the Sixes and what about the block off plate.
I was reading in The Falcon Performance book that the mechanical pumps can cause a flat spot on the cams. Since I'm replacing my cam in the next coupe of weeks I wondering if I should go with an electric pump instead?????
