mr.mustang
I installed the 2 barrel carb but haven't figured out how to work with the choke. its a 5200 and it has two male outlet. One being directly on the choke and there is another male that is coming from a wire. which one do i feed or ground? Also can the choke not being installed cause the car to shut off after 20 mins? after it shuts off it will not turn on unless i put gas/starting fluid directly in the carb then it runs like a champ. I check the fuel lines and they seem to be ok and it does not make sense that it runs perfect for 20 min then cuts off. any input would be helpful. thanks
