65-coupe
My car has been running really good. But the other day it started to sound like it was spark knocking. I run 93 octane in it. I checked the timing and it was where it should be at 12. I lowered the timing down to 6 and it still made the noise. It only does it when I accelerate going forward. It will not do it in reverse even at high rpms. If I hold the brake and give it gas it still does not do it. If I go in reverse and then stop quick it will make the nose while braking hard. But does not do it braking going forward. I think maybe something to do with the thrush bearing maybe. What ever it is it seems to only do it when the engine is being pushed back. I did check the torq convertor bolts and they were tight. I have a DUI dist and it is working properly/ vac advance/ mech advance. Any help would be great.
