72maverick
Where did you find the arp bolt
drag-200stang":1444iyl2 said:I have had luck with this type of situation by turning the bolt counter clockwise and pulling out at the same time...Try prying on the washer with a screwdriver wile turning...A little creep lube will also help.
drag-200stang":2tw24l9y said:I have had luck with this type of situation by turning the bolt counter clockwise and pulling out at the same time...Try prying on the washer with a screwdriver wile turning...A little creep lube will also help.
