Mercury Mike
Went through my entire ignition system. I had a new coil, alternator, and battery from when I installed my engine over a year ago (wow, has it been that long already?). I changed the points, condensor, and all last week. My car will turn over, start, and then just kind of thump around for a second before I die. If I give it gas, there's no effect, the thumping doesn't speed up or anything. Could it be a vacuum leak? Bad gas? I rebuilt my carb way back when, and it ran good, but since I figured it might be the carb, I swapped to another 1bbl I had laying around that had been kept in a dry place. Same exact effect. I went inside for a coke, came back out, turned it over, fired it up, and it idled and ran GREAT! I decided to put it in reverse and take it around the block, 'cause why not. I got home, put it in park, went upstairs. Came out today, went to start it, and again same problem. Could it be a float adjustment? Anywhere specific to look in the wiring? Give me some ideas, I'll go out tomorrow and try it all out, then come back and give a full report on what happens. =D Thanks all.
