Wanted Ford 250 Carb Spacer
Ba Mustang
I am looking for this carb spacer. Unfortunately the threads have pulled out of one side. So my options are to replace it or helicoil the stud threads. I saw one on ebay for $45, was hoping someone might have one a little cheaper.
Are you actually using the EGR valve that is hung off the side of your current spacer? There is an older version of the spacer that does not have that big EGR mounting flange on it.
Would it be possible to just get a longer stud and put a nut on the end? Can’t quite tell from the picture if there is enough room.
