I'm brand new to the board, but thought I'd share my exploits. I've finally collected almost all the old-school hot rod bits I can find for the 223 in my '56 Effie: Offy 2 pot intake, Patriot split header with Smithy's, Barker hi-lift rocker arms (for both I & E), OE steel head gasket & Pertronix Ignitor II w/ Flamethrower coil. The previous owner says the engine was rebuilt, and given how smooth it runs and how clean it looks under the valve & lifter covers, I think he was telling the truth.
Before I start throwing part at it, I need to compression test the engine, and then if I can finagle some dyno time, I'd like to get a hp/torque baseline before adding the go-fast parts to see what the final result produces.
One other thing... I'm hoping to make this truck my daily driver, so I've opted to swap a T-5 for the old 3-on-the-tree using one of John Mummert's adaptors... not cheap, but if I can roll w/ SoCal freeway traffic and not get run over by semi's, it will be worth it.
I've been sponging info from the members here for a couple of months, but would appreciate any additional thoughts before I start wrenching in the next couple of weeks.
I'd like to know how much anyone's successfully shaved off the head, what's the most compression anyone's successfully run (keep in mind my truck's intended to be a daily driver), and what the max RPM is that you twist the stock motor to (I don't want to go into the bottom end to balance things, replace rod bolts, etc.)?
