714 mustang
i am using the ARP head stud kit and noticed that the thread pitch is a fine thread on the one side not going in to the block wont that double the amount torq being put on the head thearefore overtorqing the head?
Asa":pbk57id9 said:nope
think about it, there's no torque wrench for fine threaded bolts Vs coarse threaded bolts
where torque readings are concerned, threads is threads, you're setting your wrench for a certain amount, when it gets there it lets you know (either by clicking or through the dial)
there are a few posts and threads that go into better explanation than that, i'll try and find them
Asa":5npyeces said:nope
'68falconohio":5qz3r0jz said:I disagree, it matters how many TPI the bolt is. The torque wrench will indeed only read how much force it takes to rotate the nut but the amount of tensile force(clamping force) exerted on the stud will be different between a 10 TPI and a 20 TPI both torqued to 10 ft.lbs......
rbohm":s4qi0lwf said:..... 10ft/lbs is 10ft/lbs. however with fine threads the clamping force is greater.....
69.5Mav":2zvrbh2u said:The only way to accurately measure the clamping force of a head bolt or stud is to put a Strain gage in between the two surfaces you are clamping together.....
