Yes, you pretty much have to pull and reinstall. They may be re-usable - or you could look into hiring/buying the cam bearing tool. New bearings should be less than $20 if our local prices are any guide.
I want that shop to explain how improved efficiency consumes more fuel.
The other thing you are seeing here, is the time blowout. Stay on top of people, and you should be running it late this month.
Have the rods been closed and honed, or beam polished and peened? The former is good practice, the latter an indulgence in most uses.
Also good to buy/borrow are some half-decent digital calipers. A $60 set will likely do fine. Put them in the box when not used, and don't loan them out (yep, and I said to borrow them!
). That will keep a cheap set in "Rolls-Royce" condition for much longer. You can check crankpins and journals quite well with them.
