Use a can of Berryman's B-12 and blow the bleeds clean from inside out (have to come in where metering plate comes off)
turbo_fairlane_200":1hwrrczp said:so prob should jsut blow out all the holes in the main body from the metering block side then? should I take out the adjusting screws when I do this? (place for junk to blow out?)
turbo_fairlane_200":2esxgih3 said:well the carb was presivously rebuilt when I got it
turbo_fairlane_200":2997n5gx said:as far as I understand the 2300 is just a 4bbl with no secondaires on it.
turbo_fairlane_200":3odor8gx said:ok I made some progress tonight.
1) I put in new bowl and block gaskets (old ones were about toast anyway)
2) so it seems I have a float level issue. I have it adjusted to the max and it still won't hold a proper level.
3) now I am starting to wonder if my pump is putting out too much pressure?
4) this whole time I have reall been fitting a float level problem....just barely adjust it and it overflows....and it keeps overflowing all of a sudden for some reason.
5) I have a regulator I could toss on tonight and see if I can turn down the pressure and make any change in it.
6) I am gonna double check to make sure it is in the right direction...as I think I moved the float UP and not DOWN in the bowl..
turbo_fairlane_200":39owm07e said:1) I went the other direction.....IDLED PERFECT, not needed, running fine now
2) I get back and there is some vapors form under the hood....pop it and find oil all over the drivers side near the front. I have my pcv tube laying loose
