The idea is great, Dave, but there are a few issuues to contend with.
First. The injectors need enough space clear the cold start choke, and they have to be run off a Ford truck throttle position sensor. There needs to be an electronic structure which locks out the injectors on start up unless you want it to flood the beast. You could trigger the first injector via a Bosch map sensor in the intake, or just use the Manifold Absolute pressure sensor from an Alloy Head XF Falcon (I have one here if you need it). When the voltage indicates a sub 12"Hg pressure (little vaccum), it could jettison the first stage of fuel, when it goes below 6"Hg, it could then add the second injector to the party!
Second, the injectors need a standard line pressure to operate. Ford EFI pumps for port injection run 80 psi, and then have a return line to control fuel pressure at the injector. Since its hard to beat 7 psi with a stock Carter pump, each time you have a closed circuit cyle delievering 12volts to the injectors, you'll end up dropping the hydraulic head and float level. So the stock carby operation will be impaired. Remember, a 4.9 Six injector at 80% duty cylce can give enough fuel to give well over 40 hp, so two injectors is enough to create mayhem if they get locked on.
If you can get that operating without killing yourself, you'll be a the first EFI log headed 250 punter in the Americas! Rock on.
Oh, read the disclaimer below. We all believe in you and want you to suceed, but if the device fails, the Candian Mounties will be wanting
my head on a spike for 'aiding and abetting' :roll:
:x
